BMW 328 IA E36
  • Re: BMW 328 IA E36
    Regelboken är så jävla snurrigt skriven och på så dålig engelska så inte ens de som skrev den vet vad det menas...
    Men här är en förklaring av Klettman som fetrm många om och men kom fram till följande:
    Clarification
    As we still have some discussions about the classification i would like to clarify some facts:
    Experienced:
    It is allowed to install one speaker with a diameter of max. 10 cm per side on the A-Pillar, Mirror Triangle or if available into the dashboard at the OEM location with no changes on the surface of the dashboard.
    This means also the OEM Grill on the dashboard.
    Advanced:
    It is allowed to install Speakers with a Diameter of max. 10 cm to the A-Pillar, Mirror triangle, or if available into the Dashboard at the OEM location with no changes on the surface of the dashboard. This means also the OEM Grill. But here it is allowed to use more than one speaker per side. Also a two way system in the A-Pillar is possible. The Speaker Pods must be fixed at the A-Pillar/Mirror Triangle and are not allowed to touch the dashboard.
    In both categories it is allowed to build speakers into the doors but not higher than the dashboard level. Underneath the OEM Grills on the dashboard any modification is allowed.
    greetz
    the klettman
    På riktig engelska borde ordet OR i formuleringen för Advanced (efter mirror triangle) bytas ut mot ett AND vilket betyder att man kan använda flera installationsplatser samtidigt OCH använda fler än ett element per sida i Advanced.
    De har även skrivet om regeln för OEM galler i dessa klasser i det addendum de nyligen släppt:
    In SQ Experienced and Advanced the surface of the dashboard has to follow the
    OEM design. Speaker adapter rings can be used and grills may be changed, but
    must not protrude from the OEM surface.
    Only OEM locations are allowed for installing speakers.
    Som sagt.... det fanns en bättre regelförklaring, men den var inte tysk så den skrotades...
    Roger Edvinsson
      Clarification
      Experienced:
      Advanced:
      greetz
      the klettman
      *himlar med ögonen*
      Men dåså.....
        Clarification
        Experienced:
        Advanced:
        greetz
        the klettman
        Detta låter ju helt underbart.. Kan någon annan ge en second opinion innan jag sätter igång och river mina a-stolpar? :3
        When you have eliminated the impossible, whatever remains, however improbable, must be the truth.
        Shinichi Kudo (Detective Conan)
          Tack Jalle, stabilt!
            Kollar man på bilderna och bläddrar fram och tillbaka så tolkar jag det som att du kan ha 2 element i a-stolpen så länge de inte överstiger 10cm.
            Annars få du dra ett pm till Per Söder.
            Octan
            OctanAudio
            Fegens Vandrarhem
            Bilstereoblog
            Team Ljudbyggaren
              Jag med. Därför så skönt att se att Experience endast tillåter ett element på "udda plats" medans advanced tillåter två. Gör det tokmkt enklare att sortera ut.
                Det står SPEAKERS vilket om det är korrekt engelska i texten inte skall begränsa dig till två element.
                Men det är helt klart luddigt. ;-)
                Roger Edvinsson
                  Tack så mycket! Jag återkommer så fort jag läkt tillräckligt från min operation i fredags så att jag åtminstone klarar av att sova en hel natt ^^
                    Då syns vi på Ljudia på lördag då ;-)
                    Reglerna är inte helt solklara och det är tur vi har engagerade personer som Jalle som är insatt i Emmas regelverk sen lång tid tillbaka som kan förklara lite mer :-)
                    Bilderna var riktigt bra och tydliga och borde även läggas upp på förbundets hemsida.
                      +1
                      Håller med.
                      Bra tanke.
                      #utfyllnad
                        Hallu alla, efter typ ett halvår med att absolut ingenting har hänt så har äntligen ombyggnationen för 2014 börjat :3
                        Planen är nu att köra EAD E100HD nere vid kick-panelerna, E60 och Wharfedale diskanter uppe i A-stolpen. Allt har varit provmonterat temporärt för att testa vinklar och positionering.
                        Dagens arbete:
                        provmontering efter att diskanterna är fastsatta och spacklade
                        Ungefär hur det kommer se ut med högtalartyget på
                          Kul å se att det börjar hända saker igen
                          Mvh Micke
                            Härligt med framsteg, men varför högtalarfronttyg framför högtalarna?
                              Hur fixerar du diskanterna?
                              I övrigt ser det här väldigt trevligt ut, klart inspirerande!
                                Framförallt för att jag tycker att det blir stilrent på det sättet. Andra anledningen är att jag är beredd att 80% av allt SQ folk skulle vara mot min diskant-placering och högtalartyg döljer den litegrann :3
                                Gårdagens-arbete:
                                Poddarna ska kläs efter montering, som kommer vara dagens arbete. Tanken är att ta ett M10 rör, M6 bult, sedan så finns det såna där fina gäng-nitar som jag kan fästa i a-stolpen så kan jag skruva fast poddarna från insidan, plus gömma kablarna :3 Får se hur detta slutar upp under dagen !
