1st Audison SRx5
5ch steg som kan driva hela din anläggning.
Steget är aldrig inkopplat utan endast uppackat!
Säljes för 1800kr eller högstbjudande
OUTPUT POWER (RMS) •
5Ch 55Wx4 (4Ω)+ 185Wx 1 (4Ω) •
5Ch 75Wx 4 (2Ω)+ 160Wx 1 (4Ω) •
5Ch 50Wx4 (4Ω)+ 300Wx 1 (2Ω) •
5Ch 70Wx 4 (2Ω)+ 260Wx 1 (2Ω) •
3Ch 150Wx 2 (4Ω)+ 160Wx 1 (4Ω) •
3Ch 140Wx 2 (4Ω)+ 260Wx 1 (2Ω)
FILTER
FRONT Ch Bypass / Hi-pass: 50 ÷ 5k Hz @ 12 dB/Oct.
REAR Ch Bypass / Hi-pass / Band pass: 50 ÷ 5k Hz @ 12 dB/Oct.
SUB Ch Bypass / Lo-pass: 50 ÷ 220Hz@24 dB/Oct.
BxLxH(mm): 216x470x56
Vikt: 4,65kg
Helix P203
1 par oöppnade och 1 par bättre beg.
Oöppnade 850kr
Bättre beg 500kr
3" Bredbandshögtalare
With immediate effect the new 3 inch midrange speaker P203 enriches the
HELIX product line. The new loudspeaker „made in Germany“ ist perfectly
adjusted to the existing systems of the Precision-Series and forms a very
audiophile 3-way-system together with the tweeter P1 and the midbass
speaker P206. With its hand-scooped sisal-cone the P203 meets the highest
demands concerning sound quality. Once again, HELIX combines
precise manufacturing and the pure joy of music.
Technical Data:
* 3 inch midrange speaker with hand-scooped sisal cone
* Power RMS / Max: 30 / 50 Watts
* Frequency range: 125 Hz - 21 kHz
* Sensitivity: 84 dB 1W/1m
* Impedance: 4 Ohm
* Mounting depth: 34 mm
http://www.ai-group.se/?tuotteet&tuo...26&teksti=P203
Bilder kan ordnas via mejl!
Köpare står för frakt!
FILTER
Vikt: 4,65kg
Helix P203
Oöppnade 850kr
Bättre beg 500kr
Technical Data:
* Impedance: 4 Ohm
