Har en 15 bands eq liggandes sprillans ny i kartong som behöver hitta en ägare.
Ser ut som bilden nedan..
# 15-Band Stereo Graphic Equalizer
# Flush mount panel with heavy-duty heat sink mold
# Chrome plated finish
# Removable aluminum handle
# Dual vu meter
# Stereo input & stereo line-out
# 15-band stereo graphic equalization
# PWM switching power supply
# Master volume and fader control
# Stereo eq. on-off switch
# Input level volume
# Input Impedance: 20K ohm
# Out Impedance: 150K ohm
# T.H.D.: 0.05%
# Signal to Noise Ratio: 98.9 dB
# Crossover Range: 32 Hz, 63 Hz, 100 Hz, 250 Hz, 400 Hz, 650 Hz, 1 kHz, 1.6 kHz, 2.5 kHz, 4 kHz, 6.4 kHz, 10 kHz, 14 kHz, 18 kHz 18 dB Equalization Cut
# Frequency Response 20 Hz – 30 kHz
# Dimensions: 12.5” L x 8.75” W x 2” H
# Max Output Level 9V volts
Pris: tja.. vad är det värt? Ingen aning. Men börjar väl på 100:- plus eventuell frakt.
PM eller 0704741419
# Dual vu meter
# T.H.D.: 0.05%
PM eller 0704741419
