Säljer 2st filter på auktion! Utrop 1kr/st!!!!
Nakamichi EC-200 H Aktivt 2-vägs delningsfilter
Rated Current Consumption: 40mA
Attenuation Slope: 18dB/octave
Crossover Frequencies: 1800, 2500, 3500, 4500, or 8000 Hz (independent selection for low-pass and high-pass sections)
Total Harmonic Distortion: Less than 0.003% (1kHz, 2V)
Signal-to-Noise Ratio: Better than 105dB
Input Level/Impedance: 1V/100kohms
Output Level/Impedance: 0-2V (variable)/5kohms
Maximum Input Level: 3.5V
Power Source: 14.4V DC, negative ground (10.8V - 15.6V allowable)
Dimensions: 120(w) x 35(h) x 105(d) mm
4 3/4(w) x 1 3/8(h) x 4 1/8 (d) inches
Approximate Weight: 320g/11oz.
http://www.tradera.com/Nakamichi-EC-...1405_113880812
http://www.tradera.com/Nakamichi-EC-...1405_113880813
Aultionerna är uppladdade, men ej startad i skrivande stund! Så passa på att fynda! Och bli ägare till en raritet!
