Har ett rockford fosgate punch 360,6 till salu då jag sålt av bild och allt ljud. Kom med bud !
– 40 –
Continuous Power Rating (Competition Standard) - Measured at 13.8 Battery Volts
RMS continuous power per channel, 30 Watts x 6
all channels driven into a 4Ω load
from 20 to 20,000 Hz with less than
0.05% Total Harmonic Distortion (THD)
RMS continuous power per channel, 60 Watts x 6
all channels driven into a 2Ω load
from 20 to 20,000 Hz, with less than
0.1% Total Harmonic Distortion (THD)
RMS continuous power bridged into a 120 Watts x 3
4Ω load from 20 to 20,000 Hz, with
less than 0.1% Total Harmonic Distortion (THD)
Dynamic Power Rating (IHF-202 Standard) - Measured at 14.4 Volts
Per channel into a 4Ω Load 60 Watts x 6
Per channel into a 2Ω Load 95 Watts x 6
Bridged into a 4Ω Load 190 Watts x 3
Signal-to-Noise Ratio > 100dB A-weighted
Frequency Response 20Hz-20kHz ±0.5dB
Bandwidth 10Hz-250kHz ±3dB
Damping Factor @ 4Ω >200 (at output connector)
Slew Rate 30 V/µs
IM Distortion (IHF) <0.05%
Input Impedance 20k Ohms
Input Sensitivity Variable from 300mV to 5V
Preset at the factory for 500mV
B+ Fuse Size (External to Amplifier) 50 amp or two 25 amp
Fuse Type AGU
Crossover Alignment 12dB/octave Butterworth
(XCard C) = 80Hz (.047µf)
(XCard B) = 4.5kHz (.022µf)
(XCard B) = 80Hz (.047µf)
(XCard A) = 80Hz (.047µf)
Dimensions (including end caps) 95⁄8"H x 189⁄32"W x 25⁄8"D
(24.45cm x 46.43cm x 6.67cm)
S PECIFICATIONS
– 40 –
Slew Rate 30 V/µs
Fuse Type AGU
S PECIFICATIONS
