Stetsom 4K2D. Varit igång ca halvtimmen. 6500:-
RMS Power @ 13.8V
/ <0,9% THD Mono 2 Ohms 5500 Watts
Mono 4 Ohms 3200 Watts
RMS Power @ 12.6V
/ <0,9% THD Mono 2 Ohms 4200 Watts
Mono 4 Ohms 2800 Watts
Number of Channels 1
Minimum input sensitivity 0,2V
Total Harmonic Distortion < 0,9 % THD
Signal to Noise > 90 dB
Weight 5 Kg
Crossover Frequency LOW PASS 50 to 15 KHz
Frequency Response: (FULL RANGE) 20 Hz to 15 KHz (-3dB)
Power Tension 9 to 15V
Consumption with musical signal 6 to 240 A
Consumption with BASS signal 6 to 470 A
Dimentions (H X W X L) 70 x 280 x 350 mm
Impact 5712. Varit igång ca 20min. Bud!
20-300Hz
500 Watt RMS
1000 Watt Peak
2x65mm talspole
2x2 Ohm
Phoenix gold rsdc 12". 2x4ohm 600w rms Bud!
RMS Power @ 13.8V
RMS Power @ 12.6V
Weight 5 Kg
20-300Hz
500 Watt RMS
1000 Watt Peak
2x65mm talspole
2x2 Ohm
