Säljes pga av uppgradering i tjejens bil så lugnt spelat med och i kalas skick!
1000:- + frakt
RMS Power @ 4 Ohm – 13,8 V 250W RMS
Power @ 2 Ohm – 13,8 V 350W RMS
PWM Mos-Fet Power supply
Mono channel mode
High-Level & Low-Level Input
2 Ohm stable stereo operation
Adjustable Input Level
Non excludible Lowpass Crossover
Adjustable Bass Boost up to +18 dB
Socket for Bass boost remote
Overheating protection
Reverse polarity protection
Protection against speakers shortcut
RCA Line-Out
RMS Power @ 4 Ohm – 13,8 V W 1 x 250
RMS Power @ 2 Ohm – 13,8 V W 1 x 350
RMS Power Bridged @ 4 Ohm – 13,8 V ---
Total Harmonic Distortion % 0,05
Adjustable Input level V 0,12 ÷ 3,5
Input Impedance kOhm 22
Frequency Response Hz 9 ÷ 155
Signal to Noise Ratio dB > 93
Damping Factor 200
Fixed High-Pass Filter Hz ---
Adjustable Low-Pass Filter Hz 35 ÷ 155
Adjustable Bass-Boost dB 0/+ 18
Socket for Bass-Boost Remote Control Yes
Line Output Full Range Yes
Outside Dimensions (WxHxL) mm 240x50x370
1000:- + frakt
Mono channel mode
RCA Line-Out
Damping Factor 200
