Behöver hjälp med en spl låda till en spl-300D2 den
kommer matas med 2st kicker zx1500.1
lite värden på basen
Specifications
Model SPL-300D2
Size 325mm ( 12" )
Power handling (RMS/Peak)
1500/3000 W
Nominal impedance
2 x 2 Ohm
Mounting depth
206 mm
Mounting diameter 288 mm
Magnet weight
300 oz
Voice Coil diameter
76 mm ( 3 " )
Voice Coil Type/Material
DVC / BASV
Weight 23 kg
Voice Coils connection series parallel
Impedance 4 Ohm 1 Ohm
Fs
33.4 Hz 34.3 Hz
Vas
23.2 L 23.9 L
Qts
0.352 0.399
Qes
0.388 0.437
Qms
3.749 4.556
Xmax (lin/peak)
11.5/23 mm 11.5/23 mm
Re 3.8 Ohm 0.95 Ohm
Mms 370 g 370 g
BL 28.19 TM 12.98 TM
SPL (1W/1m) 85.5 dB 85.3 dB
mvh manta
Specifications
Model SPL-300D2
Size 325mm ( 12" )
1500/3000 W
Nominal impedance
2 x 2 Ohm
Mounting depth
206 mm
Magnet weight
300 oz
Voice Coil diameter
76 mm ( 3 " )
DVC / BASV
Weight 23 kg
Fs
33.4 Hz 34.3 Hz
Vas
23.2 L 23.9 L
Qts
0.352 0.399
Qes
0.388 0.437
Qms
3.749 4.556
Xmax (lin/peak)
Re 3.8 Ohm 0.95 Ohm
Mms 370 g 370 g
mvh manta
