Re: Saab 9-3 Aero from the UK
Couple hours deadening today, just the rear shelf this time and a quick swap of the 6x9's for my Genesis subs.
The shelf comes off pretty easy, just drop both seat backs then carefully remove these 3 plastic lugs, lift up at the front and pull it out
With that out the way your left with this, so mine has the 11 speaker system? 5 up front & 6 in the shelf.
I think its 6x9's for bass, 4" for mids and looks like a 2" tweeter for highs. When I eventually fit the amps ill just wire up the 6x9's only, disconnect the other 2 but leave them in situ.
I wanted to seal up these 3 holes, then add some deadening here and there ontop of the shelf, I've also done underneath.
To get the 6x9's out you have to remove both C pillar covers as these block one of the screws
Shelf deadened
Gennesis subs fitted....but not working :wall:
No idea what's happened here, they could be goosed but visually look in vgc. I've wired up the old 6x9's and these work fine, the p69's are showing no signs of life though, no sound and no movement in the cones?
Do these P69's have to be amped to get any sound from them? I'm getting nothing from the headunit :?
Shelf deadened
I've tried swapping power wires over but still no joy. Main thing it's working and nothing's set on fire!
(missis is doing her nut back home!)
