Tjo.
Som Annonsen lyder så har vi ett AQ20 att sälja.
**Audioque 20**
Specifications
Model AQ20
Input Sensitivity 0.15V ~ 5V
Variable Subsonic Filter 10Hz ~ 50Hz @ 24dB/Slope
Variable Low Pass Filter 35Hz ~ 250Hz @ 24dB/Slope
Tested Voltage 12.5V
THD <1%
Cont. Power @ 1 ohm 8000w
Damping Factor 150 <
Dynamic Power 20,000W
Signal to Noise Ratio 100dB <
Dimensions (mm) 980mm (L) x 300mm (W) x 76mm (H)
Dimensions (in) 38.58in (L) x 11.8in (W) x 3in (H)
Weight 63 lbs
14000:-
Tele 026260809
**Audioque 20**
Specifications
Model AQ20
THD <1%
Weight 63 lbs
14000:-
Tele 026260809
säljes eller bytes mot batterier!
